toffee_pie
- Joined Oct 31, 2009
- 235
for womenI recently discovered, that somehow in the USA? turning a round is called this way, even though both turns have the same number of stopping points. How do you tell a difference? Apparently a two point turn is when you first go into corner street, then back up and then go in opposite direction, and a three point turn is basically the same thing only done on a straight piece of road.
Any ideas on why it is called like that?
Also, what constitutes a point? I would say that logically it is the point where you reverse the direction of the car, so a two point would be forward-reverse-forward maneuvre. So naturally after a three point turn - forward-reverse-forward-reverse you would be left going in reverse?
turn 1) reverse backward.
turn 2) look at mirror, check hair and bust while reversing back more.
turn 3) drive forward
turn 4) driver forward a bit more
turn 5) drive back at 45 degrees while looking at hair
turn 6) drive forward at some other angle
turn 7) drive back until you hit a kerb
turn 8) drive forward until you seem good looking enough to continue.
