I recently discovered, that somehow in the USA? turning a round is called this way, even though both turns have the same number of stopping points. How do you tell a difference? Apparently a two point turn is when you first go into corner street, then back up and then go in opposite direction, and a three point turn is basically the same thing only done on a straight piece of road.
Any ideas on why it is called like that?
Also, what constitutes a point? I would say that logically it is the point where you reverse the direction of the car, so a two point would be forward-reverse-forward maneuvre. So naturally after a three point turn - forward-reverse-forward-reverse you would be left going in reverse?
