two PAVM
Discussion in 'General Electronics Chat' started by DexterMccoy, Apr 21, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    When using Two Phase angle volt meters with the same reference sync frequency but the Reference voltage is different
    Example
    Phase angle volt meter#1 Reference at 60hz at 120Volts
    Phase angle volt meter#2 Reference at 60hz at 26volts
    What does having a different voltage on the REFERENCE input do?
    The Reference sync/frequency is the same only the voltage is different
  2. bance
    Member
    Aug 11, 2012
    315
    34
    Does it give a different reading?
  3. DexterMccoy
    Feb 19, 2014
    429
    Not that I know of, it seems to be the same
    But maybe it does for some reason, but i'm not sure what the reason is
    Why would having a different voltage on the reference inputs make a difference in the measurement?
  4. antonv
    Member
    Nov 27, 2012
    149
    27
    I suspect the reference input is for phase only, the voltage just has to be in an acceptable range for the phase detection circuitry to be accurate.
  5. DexterMccoy
    Feb 19, 2014
    429
    Yes but one PAVM says to be at 120VAC at 60hz and the other PAVM says to be at 26 VAC at 60hz
    What is the difference between 120VAC VS 26 VAC when using the Reference input on a PAVM?
    It will do what different?
  6. shortbus
    Sep 30, 2009
    4,096
    1,692
    The difference is - 94VAC
Thread Status:
