two out of five code error detector
Discussion in 'The Projects Forum' started by r_sagarraju, Oct 4, 2007.
  1. r_sagarraju
    Oct 4, 2007
    TOFEDetector
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. r_sagarraju
    Oct 4, 2007
    Thanks @Beenthere
  4. techroomt
    May 19, 2004
    198
    why not drop the word into a register and then performing a compare with logic gates?
  5. r_sagarraju
    Oct 4, 2007
    @techroomt
    i didnt understand ur logic....can u explain it more clearly.........
  6. techroomt
    May 19, 2004
    198
    the register is just a means to hold your status word fror decoding, not required if it is already stored or available elsewhere. the bits can then be inputs to some and & or gates to "watch" for the specific pattern to output a high signal (or whatever stste your circuit requires). this is not much unlike a parity checker circuit honestly.
  7. techroomt
    May 19, 2004
    198
    i am afraid we will need more detail of your application and conditions to help any further.
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Simple.
    First, draw up a 32 line truth table for all possible states of the five inputs. Outputs will be "0" for any input combination containing two and only two "1." Output will "1" for all other inputs.
    Next, study the table and look for patterns. Create a logic circuit to satisfy the truth table.
    Hint: There are only ten of the thirty-two states which will not be error states.
  9. r_sagarraju
    Oct 4, 2007
    Thanks a lot thingmaker......
