Two inputs at different voltages in parallel
Discussion in 'The Projects Forum' started by jonfarrugia, Jan 7, 2014.
  1. jonfarrugia
    Feb 19, 2010
    20
    I have two micro processor in which I need to connect both of them to the same single pole switch which is grounded on one side. One of the micro processors is sitting at 12v while the other is sitting at 5v. I just cant connect these two inputs together and than connect them to the grounded switch...can I?
    connecting them together may cause damage or premature triggering. What circuit should go between them? They are just inputs so there should only be a few ma of current. I was considering a diode between the inputs but thought the voltage drop across the diode might cause issues.
    The current circuit is very similar to the one attached.
    azizi92 likes this.
  2. wayneh
    Sep 9, 2010
    12,382
    3,240
    That arrangement will cause a bit more current to flow from the 12V source than from the 5V source. You could increase the 10K resistor to reduce the current. Otherwise I don't see a problem, but I must admit I don't quite understand why the micro is sourcing current at its input pin?
    azizi92 likes this.
  3. inwo
    Nov 7, 2013
    2,435
    315
    I think diodes would be better.
    azizi92 likes this.
  4. inwo
    Nov 7, 2013
    2,435
    315
    What is the "logic low" level?
  5. jonfarrugia
    Feb 19, 2010
    20
    Do you mean something like this:
  6. jonfarrugia
    Feb 19, 2010
    20
    Im a bit confused...when the switch closes the level is 0v?
  7. inwo
    Nov 7, 2013
    2,435
    315
    No, just the diodes.
    With the resistors, and switch "off", the 5 volt input will see 12 volts. Maybe that's OK.
    A diode on the 5v is all you need, as it would be biased off with switch open.
  8. jonfarrugia
    Feb 19, 2010
    20
    OK so like this:
  9. inwo
    Nov 7, 2013
    2,435
    315
    I mean will it be considered "low" at .6 volts. TTL was 0 to .8 volts.
    Your input specs may be different.
  10. jonfarrugia
    Feb 19, 2010
    20
    The 5v microprocessor is an Arduino Mega...I'd need to look at the specs for it
  11. jonfarrugia
    Feb 19, 2010
    20
    looks like a low is 0-1.5 and high is 2-5
  12. inwo
    Nov 7, 2013
    2,435
    315
    Except no resistors.
    But it only works if .6 volts will be seen as "logic low".
    If not use a diode with very low forward drop.
  13. inwo
    Nov 7, 2013
    2,435
    315
    Good to go then.
    One diode on the 5v leg.
    Another on the 12v can't hurt.
    Also, the diodes must have some "keep alive" current thru them.
    Are there pull-ups?
    jonfarrugia likes this.
