Two identical circuit boards, one working one not
wars0696
Joined Nov 24, 2008
9
I have two identical circuit boards using IC MM74HC123 one manufactured by Fairchild Semiconductor the other by Philips. The Fairchild chip when used in the circuit will announce any length of message the Philip circuit won't announce the longer messages. I don't have a circuit diagram for the board. I only difference on the datasheet is differences in the propagation delay, output transition time and power dissipation capacitance. Could anyone please tell me which of these would course the problem and why?
bertus
Joined Apr 5, 2008
22,278
What is the powersupply voltage of the boards ?
The HC series may work from 2 to 6 volts.
The HCT series may work from 4.5 to 5.5 volts.
Greetings,
Bertus
jpanhalt
Joined Jan 18, 2008
11,087
Are you talking about the chip or the boards? How can you be sure the boards are identical?
John
mik3
Joined Feb 4, 2008
4,843
Then one chip is problematic and needs replacement. Take the good chip and check it on both boards to see if they are both good.
wars0696
Joined Nov 24, 2008
9
I have done this, and ordered replacement Fairchild chips, but I was just wondering why the problem was due to the Philips chip and if the higher maxium propergation delays and lower power dissipation capacitance would explain this
mik3
Joined Feb 4, 2008
4,843
Maybe! What board is it? Can you post links for both the datasheets of the Fairchild and Philips chips to compare them?
Skeebopstop
Joined Jan 9, 2009
358
One thing I noticed are Vref1 and Vref2 in the phillips schematic of the IC aren't exposed or described. If Vref1 and Vref2 of the schmitt triggers differed from chip to chip your Rext and Cext values may not be chosen correctly for such interchangeabaility.
hgmjr
Joined Jan 28, 2005
9,027
If you compare the datasheets for the Phillips 74HC123 and the Fairchild 74HC123 you will find that the formula for the Phillips one-shot's pulsewidth is T = 0.45*R*C while the formula for the Fairchild 74HC123 is t=R*C. This difference is enough in many cases to prevent one manufacturer's device from replacing the device from another manufacturer. There is another semiconductor manufacturer's 74HC123 whose formula is t=0.7*R*C.
It is for this reason that the company I work for has a strict ban on the use of 74HC123 in any of our designs.
hgmjr
Sparky
Joined Aug 1, 2005
75
Can you scope the faulty board and see if the Philips part is producing a pulse?
I agree with hgmjr a "xx74xx123" is not the same as another "xx74xx123". Working with 1-shots can be frustrating if / when the circuit is designed to work with a certain pulse width.
-Sparky
