Two diodes used with 1 relay
Discussion in 'The Projects Forum' started by nitinsharmaece, Jun 27, 2012.
  1. nitinsharmaece
    Jun 27, 2012
    I want to know why sometimes 2 diodes are used with relay, despite 1 is enough for safety purpose.... Also tell me the applications where 2 diodes are used ??:rolleyes:
  2. absf
    Dec 29, 2010
    1,493
    374
    I only know that there is only one diode connected across the relay coil to prevent back emf that would destroy the driving transistor. Where is the second diode connected?
    Allen
  3. wayneh
    Sep 9, 2010
    12,382
    3,241
    Using two would increase the amperage than can be handled without finding a new part with a higher rating. Just speculating
  4. crutschow
    Mar 14, 2008
    13,496
    3,373
    Two diodes in series can be placed across the coil for increased reliability. If one diode shorts, the other still works, allowing the relay to continue to function.
    strantor likes this.
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    absf likes this.
  6. KMoffett
    Dec 19, 2007
    2,584
    234
  7. wayneh
    Sep 9, 2010
    12,382
    3,241
    It's one of those things that seem so obvious once you see it. Cool.
  8. Smoke_Maker
    Sep 24, 2007
    126
    15
    SgtWookie likes this.
  9. ArmbrusterJo
    Jun 27, 2012
    5
  10. ErnieM
    Apr 24, 2011
    7,436
    1,626
    John from the Great State of Texas nailed it!
    I have the inside track on that: I just designed the coil suppression network for "a major relay manufacturer" (which may or may not be TE) and this describes it's function exactly. Basically it's just a zener and a diode on a .1x.22" board and two fly leads.
    They put our part inside their relay, actually wrap it over the coil.
    One thing to note is the zener voltage ADDS to the applied voltage during turn off, so don't be stingy with the controlling element's voltage rating.
