two closed going open contacts from one
Discussion in 'General Electronics Chat' started by kevmac72, Aug 26, 2007.
  1. kevmac72
    Mar 12, 2007
    i have a pir which gives a closed going open contact. My problem is that i need two independant outputs to trigger two devices. when i loop through both devices - throught the closed going open, only one will trigger. Does any one know of a solution which preferably does not use power
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What are you referring to with the term "pir"?
    hgmjr
  3. Voltboy
    Jan 10, 2007
    197
    I think he's referring to a pyroelectrical infrared
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I was thinking either "passive infrared" or "photo infrared". I just want to make sure I was clear on what was meant.
    hgmjr
  5. kevmac72
    Mar 12, 2007
    Sorry, i was referring to Passive infra red - alarm sensor
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I suppose you could pass current through your normally open contacts (assuming you are referring to a relay) and use the interruption to trigger your two external events. As to using no power, that restriction makes it impossible to devise any external circuit. A device may use very little power, but it will need some in order to function.
  7. kevmac72
    Mar 12, 2007
    thankyou i think i have solved it with no additional power...using diodes to stop the original signal corrupting the second
