Two boolean functions
Discussion in 'Homework Help' started by mannycalavera, Jan 26, 2009.
  1. mannycalavera
    Jan 26, 2009
    Hello, i need some help with a boolean function, my task is to use only a) NAND gates and b) only NOR gates. The function is
    F=A'BC' + A'BC+AB'C (i use the ' notification for NOT)
    So i have to convert it to solely NAND gates. Any suggestions?
    I try to implement Demorgans law, but i receive a questionable result.
    I would be very thankfull for anykind of hints/solutions?
    P.S. im not trying just to copy the homework, but to understand it :)
  2. vvkannan
    Aug 9, 2008
    138
    11
    hello mannycalavera,
    implement the boolean expression using all gates first(i.e AND,OR,NOT)
    now replace the single input NOT gate by NAND by splitting the input into two inputs)
    now remember that NAND gate is AND added with NOT and hence when you see a AND add two NOT gates after that(2 NOTs will not make any difference).
    REPLACE the AND and 1 NOT with NAND( DEMORGAN'S) and the other NOT as described in above step.
    remember a NOT before OR can be replaced by NAND.so add 2 NOTs before OR.
    replcae 1 NOT and OR with NAND and the other NOT as described previously.
    similar procedure can be adopted for NOT but remember
    NOT added before AND is NOR
    NOT added after OR is NOR
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    It might help you to read through the material in the AAC ebook on Boolean Algebra. The presentation is straightforward and relatively easy to follow.
    hgmjr
  4. Ratch
    Mar 20, 2007
    1,068
    mannycalavera,
    The first thing you should do is simplify the Boolean expression you want to implement.
    A'BC' + A'BC+AB'C
    A'B(C' + C) + AB'C
    A'B + AB'C
    Ratch
  5. mannycalavera
    Jan 26, 2009
    still i cannot reach the solution
  6. Skeebopstop
    Jan 9, 2009
    358
    Using Ratch's simplification:
    A'B + ABC'
    The attached circuit should do this.
