Two 50Hz sinusoidal Waveforms Va and Vb, Va lags Vb by 27°.
Discussion in 'General Electronics Chat' started by RyanB193, May 3, 2013.
  1. RyanB193
    May 3, 2013
    Two 50Hz sinusoidal waveforms, Va and Vb, where Va lags Vb by 27°. add the sinusoidal graphs Va and Vb by a graphical method and draw the resultant waveform. Can you help me find the correct "graphical method" to use to solve this problem.
    Thank you!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    What is the problem ;). Divide the waves into intervals. Measure the values and add them together. Then interpolate between the segments.
    RyanB193 likes this.
  3. crutschow
    Mar 14, 2008
    13,519
    3,386
    At any point in time, just add the value of the two waveform voltages, including the sign, to get the added value. Do this for as many points in time as you need to get a smooth summed resulting waveform.
