Two 4-bit Binary Adder using SPDT switches and only 1 Full Adder Circuit
Discussion in 'Homework Help' started by arwayeyen, Mar 1, 2012.
  1. arwayeyen
    Mar 1, 2012
    Title says it all. I need help in designing a circuit that has two 4-bit binary adder using SPDT switches. The catch is to make this with just 1 Full Adder circuit. If anyone could please help me out with this one along with a diagram, that would be great. :)
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    I imagine this is homework. I moved it to the right place.
    Can you elaborate a bit more?
    Must the two results calculate simultaneously?
    How many bits does the full adder have?
    A full question repost would be helpful.
  3. Kn0x_14
    Mar 2, 2012
    6
    we also have the same problem
    input:two 4 bit binary numbers implemented by SPDT switches
    output: Sum shown through LEDs
    the circuit must contain only one full adder
    please help us...
    thanks...
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I imagine you want the following:
    Use a 1-bit full adder in a sequential circuit to process the input digits step by step. You will need 4 cycles to process the whole input and some kind of storage, ie shift register.
    But I don't see how it can be done with *only* one full adder.
    As I said, repost the original homework question.
  5. Kn0x_14
    Mar 2, 2012
    6
    4-bit Binary Adder
    Input: 2 4-bit binary numbers implemented by SPDT switches
    Output: Sum shown through LEDs
    Your circuit must add two binary numbers correctly. You may add additional control if you wish to.
    Note: Your circuit must contain only ONE (1) Full-Adder circuit and provide me a schematic diagram.
    NOTE:
    You will use a single (ONE) FULL-ADDER Circuit
    Any Implementation of a Full-Adder is still a full-adder.
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    Ok, this is a bit fuzzy. What is the context of your course at the moment? Are you still at the basic logic functions (addition, Boolean algebra) or have you reached sequential circuits?
    I 'd like to interpret the lack of a bit width specification for the full adder as you being able to use a 4-bit adder, like the 7483 IC.
    On the other hand, when referring to a full adder, we usually mean a 1-bit unit. But with only one 1-bit unit, this 4-bit operation is impossible.
    So what I suggest: Use a 4-bit full adder to add your two addendums. At the same time ask for a clarification from your professor. Badly expressed exercises aren't that uncommon.
  7. Kn0x_14
    Mar 2, 2012
    6
    yes we're already studying sequencial logic
  8. Georacer
    Nov 25, 2009
    5,151
    1,266
    Ok. Then could it be that your professor wants to use a 1-bit Full Adder, which you will use to add the two input numbers one bit pair at a time?
    That calls for two shift registers as input buffers and a shift register for the output storage.
    Consider this option, but keep in mind that it call for three additional ICs, plus another to provide D-Flip Flops to create a functional pipeline.
  9. Kn0x_14
    Mar 2, 2012
    6
    can you please provide me a schematic diagram for that problem? because we have to submit our circuit tomorrow if it is possible.tnx
  10. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  11. Georacer
    Nov 25, 2009
    5,151
    1,266
  12. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  13. Kn0x_14
    Mar 2, 2012
    6
    sir Geo and sir Bert thank you for all your advice it helps me a lot...
