Tweaked LM3914 circuit. Will it work ?
Discussion in 'The Projects Forum' started by Externet, Sep 10, 2014.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    775
    57
    Hi.
    There is only 5 LEDs wanted in this circuit, to display on a range of 1.2 to 7.6V input.
    Some output pins are paralleled to the same LED. Is that allowed ?
    Is this an acceptable way to set range limits ?
  2. crutschow
    Mar 14, 2008
    13,472
    3,359
    Yes, since the outputs sink current, you can parallel the outputs in the DOT mode. It just means that the top and bottom LEDs will remain lit for all input voltages above/below their respective trip points.
    DeciBel forever!
