TVS diode
Discussion in 'General Electronics Chat' started by darkmatter, May 9, 2014.
  1. darkmatter
    Dec 19, 2008
    8
    Hello Board;
    I have aTVS diode 1.5KE75A which is suppose to shunt about 20A in 100 ns . The clamp is at 103V , My question is when its in clamp mode for few nano seconds my power supply 60V is getting over volted to bout 43V , does this remaining 43v force transient current int my power supply if yes how to calculate. Sorry the question seems to be basic but I am struggling for 8 hours with this , hope to get some expert advice. Thanks.
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    It might, depending on the design of your supply.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    then why not get a tvs better suited for the job? one closer to 60 volts ?
  4. crutschow
    Mar 14, 2008
    13,523
    3,392
    What is the source of the transient?
  5. darkmatter
    Dec 19, 2008
    8
  6. darkmatter
    Dec 19, 2008
    8
    The source of transient is CDM.
  7. ErnieHorning
    Member
    Apr 17, 2014
    67
    17
    I agree, if you’re measuring more than 72 volts (max for the part) even nanoseconds will likely compromise the part.
  8. crutschow
    Mar 14, 2008
    13,523
    3,392
    Okay. What's CDM?
  9. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Judging by the OP's name, perhaps that's "celestial dark matter" :D
    I don't think such an animal exists. All the link shows is a black box. The circuitry inside is unknown.
  10. darkmatter
    Dec 19, 2008
    8
    CDM= contact discharge model .
  11. darkmatter
    Dec 19, 2008
    8
    He , he he , perhaps darkmatter is not that a mystery in present days physics.The link about converter provides only specification. Can some one judge from these type of DC-DC. If I were to know the inside circuit what should I look inside for. I plan to disect one of these.
  12. darkmatter
    Dec 19, 2008
    8
    Please find the Image below , which shows the I/P stage.
    Any Help!
  13. darkmatter
    Dec 19, 2008
    8
    Pardon me , correction Charge device model.
  14. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Here's a sim of the application of a 4us 200V spike from a 0.1 Ohm output-impedance source to your input circuit. It shows the diode clamping V(in) at 103V, a diode current peak of ~900A, and the cap voltage V(out) reaching ~80V. That exceeds the rating of your circuit by some way.
    darkmatter likes this.
  15. darkmatter
    Dec 19, 2008
    8
    Thanks, I downloaded LTspice as I have never used it before but got weared results. I couldnt cope with model file . Can you please share your .asm file with me .
  16. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Here's the asc file. Can't remember if the TVS model is an LTS native one or if it was third-party.
