Tv signal output out of usb port
Discussion in 'Computing and Networks' started by redacejr, Jun 23, 2009.
  1. redacejr
    Thread Starter Active Member
    Apr 22, 2008
    85
    ok , this is the situation:
    i have a pc in my room , which is connected via an ethernet cable to a computer reuter in another room.
    the internet provider service also has a tv service , in fact if you connect the coaxial cable core (tc antenna) to one of the pins of the ethernet plug you get reception.
    is there a way to transfer that connection from the network socket input of the pc to a usb port... so that you get a signal output from the usb?
    i dont know if you got what i mean
  2. hwy101
    May 23, 2009
    91
    28
    There is a way to do that with a SLINGBOX, you can actually watch your tv on your pc or laptop in your room or anywhere in the world I believe.
    There's another unit called AngelTrax CATV2400
