TV Not working.
Discussion in 'General Electronics Chat' started by RRITESH KAKKAR, Dec 25, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    Hello guys,
    My Tv Day before yesterday is not working when power supply is on.
    Actually there was low voltage in phase in morning since last two days what will be the problem?
    At afternoon and evening the voltage is normal but TV is not showing any response, why?
  2. #12
    Nov 30, 2010
    16,704
    7,354
    Your TV is broken.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    there is circuit that might be not properly working.
    broken?
  4. spinnaker
    Oct 29, 2009
    5,097
    1,190
    There should be a wire that comes off the back of the television. There should be prongs on the end of the wire. Look very carefully on the inside wall of your home. You should see a socket with holes similar to the plug at the end of the wire. Plug the prongs into that socket.
    Turn the television on.
    DerStrom8 likes this.
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    not working i have called service/repair men he will see.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Anyway, I open another TV how it work and learn how to repair he is screen shot.
    Please explain how it is working it has chip also..la76931k
  7. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    For a general explanation of how a TV works, the internet is better. This forum is good for detailed, specific questions, whose answers cannot be found with a simple Google search.
    If I understand right, the pictures are of a different TV from the one that is broken. But if that was the broken set, here would be my comments. It appears to be a CRT television, perhaps 10 years old. I can't read the label in the picture. Usually, it's good to take a picture of the label on the back of the TV, as that gives the full manufacturer, model number, and possibly more useful information. There is a lot of dust inside. That's ok, but for debugging, the first thing I would do is clean off as much of the dust as possible. Then everyone can see what's going on. When a TV is not turning on at all (no LEDs, no nothing), suspect a power supply issue. Assuming you have multimeter, check for power at various places, starting from the line (mains) cord. There may be a blown fuse, bad switch, or loose wire. Look for bulging electrolytic capacitors, and replace any you find. TV's typically don't have fans in them, get hot inside, and are not intended to last a long time (add a fan to an ordinary TV, and it will last basically forever). That, and time, degrades electrolytic capacitors. Look over the circuit carefully to see if anything looks like it was burned even slightly. Especially look at power transistors, and things near those transistors.
    If you are in an area where the mains voltage often goes low or off, you might want to look at what devices your neighbors are using to deal with it (what model of TV, or maybe they use a voltage stabilizer). I have no direct experience with unreliable power. The bright side is that in areas with unreliable power, labor is likely to be less expensive compared to materials, so there will be repair people you can call. Almost no one in my area (silicon valley, California) gets their TV fixed anymore. When they break, they are donated or thrown away.
    RRITESH KAKKAR likes this.
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    This is second TV from above post this is working but picture is not clear.
    I will not do because i don't want shock!!!!
  10. spinnaker
    Oct 29, 2009
    5,097
    1,190
    Time for a new television. I would think even in India there has not been a CRT TV sold in the past 10 years.
    Last picture shows a vertical deflection issue. If I recall there is sometimes an adjustment foer that.
    Because the newer TVs are more expensive to repair than replace. That old relic the OP has can be repaired. There once were several TV repairmen in my town. One of them was me when I was 15 years old. :)
  11. ISB123
    May 21, 2014
    1,240
    531
    There should be a trim pot to adjust the vertical deflection. Although I would say that you should buy a brand new TV since this one is working on very low refresh rate.
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  13. wayneh
    Sep 9, 2010
    12,394
    3,246
    You could spend a lot of time fixing your TV and then, where I live, it would be worth -$10. Note the minus sign.
    That's about what the typical disposal charge is. Save your time, take it to the recycler so that you can be rid of it for free, and move on to more productive uses of your time. This is advice from a person that finds it very hard to let go of ... junk.
    spinnaker likes this.
  14. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    The technical term is; "phutted".
  15. ian field
    Oct 27, 2012
    4,459
    792
    The EHT isn't as dangerous as the voltage magnitude suggests, most of the danger is from the charge in the capacitor formed by the inner and outer CRT coatings.
    Without that capacitance, the EHT lead has a high HF AC component that can draw a fierce arc - that can cause nasty burns, and you may not even feel it till you see it (and/or notice the smell of burning flesh).
    The biggest danger is on a set that's not starting up - the mains rectifier reservoir cap can stay charged a long time!
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    We don't use CRT now days?
    We recycler (the person who buy old stuff) buy it ?
    what the do of it?
  17. spinnaker
    Oct 29, 2009
    5,097
    1,190
    Has India been locked in the technological time warp for the past 10+ years or is it just you?
    No one i wants your old and broken junk. You will most likely need to pay to dispose of it. In the United States, many communities will have hazardous waste collection days. You can drop off things like old TVs free of charge.
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  19. nerdegutta
    Dec 15, 2009
    2,569
    806
    I think that this comment is not helping much.
    I allow myself to remind you of this text, from a sticky in this forum:
    Let's try to stay on topic. :)
    Roderick Young and JohnInTX like this.
  20. ian field
    Oct 27, 2012
    4,459
    792
    Electronics For You is a magazine published in India, it sometimes turns up on one of the magazines binary groups on Usenet.
    You can see, especially from the adverts that India is making technological leaps and bounds.
