TV-B-Gone Help
Discussion in 'The Projects Forum' started by Brennn10, Nov 5, 2007.
  1. Brennn10
    Sep 13, 2007
    Hi guys,
    Most of you know about the TV-B-Gone, but I want to make one of my own.
    Could I wire up 3V to a switch and IR LED, and would I be set? Or is it more complicated than that?
  2. HarveyH42
    Jul 22, 2007
    Much more complicated. An IR remote is a modulated signal (about 38 kHz). Different TVs use different codes. TV-B-Gone is basically a microcontroller, that store and generates these codes.
    I'm building this, sort of... I re-did the PCB, so it was single-sided, and removed a few unneeded parts. Waiting on the microcontroller and resonator (UPS guy should have been here by now...). The firmware is in 'C', which I've never used, so no idea if I compiled it correctly. The PCB I made is 1"x2" (more or less...) .
