tutorial needed on how to wire a flyback transformer
Discussion in 'The Projects Forum' started by hunterage2000, Nov 24, 2015.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    I have been searching the net for a tutorial on how to wire a flyback transformer but can't find anything. I'm not sure on all the parts I need but the book I'm referencing from says use a PM #87 pot core with 1 primary side and 1 secondary. Can anyone point me to a good source?
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
  3. hunterage2000
    May 2, 2010
    402
    Yeah I was going to make a variable flyback smps so I just need the one secondary. I have a few books on how to design them with examples but it doesn't actually go into how you make the transformer.
  4. hunterage2000
    May 2, 2010
    402
    I'm following an example which gives specific spec values of:
    Core size =PM 87
    Center pole area Acp =700 mm2
    Operating frequency =21 kHz
    Total period =45µs
    Maximum “on” period =33.3% (15 µs)
    Minimum primary volts =280 V DC
    Optimum flux density =0.15 T
    Primary turns = 42
    Secondary turns = 9
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    If you have the PM87 core, then winding 42 turns and 9 turns, with insulation between the two windings, shouln't be too difficult?
  6. hunterage2000
    May 2, 2010
    402
    Sorry actually what I have is a Pq core but I guess I can learn from this. I have attached the images of the core and a bobbin and the core fitted onto the bobbin. I think something is missing between the core and the bobbin but I don't know what.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    There should be two ferrite pieces.
    They should have likey the same shape.
    One on top and one from the bottom in the bobbin core.
    Bertus
  8. hunterage2000
    May 2, 2010
    402
    Yeah ok, I have the 2 parts now and the bobbin. What is the next step? I'm not sure if I'm asking the right questions but
    1). how is the 2 parts held together?
    2). I'm guessing that the copper wire is wrapped around each vertical section of the cores and around 2 pins on each side?
    3). Is there insulation between the copper wire and the core?
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    Add1- You can buy a special mounting clip/clamps.
    Ad2 - No, you winding the wire around this plastic bobbin.
    Ad3 - We use isolation tape to separate the windings
  10. hunterage2000
    May 2, 2010
    402
    I tried goggling transformer mounting clips/clamps and isolation tape but found nothing. Is there any guides on what I need to do? Not sure what you meant by wind around the plastic bobbin. I thought it would look like the attached image.
  11. Alec_t
    Sep 17, 2013
    5,968
    1,135
    When wound, the bobbin should look something like this.
  12. hunterage2000
    May 2, 2010
    402
    I can't figure out the steps it took to get to the finished product. I would of thought there would be some sort of step by step guide.
  13. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    There are various chips for flyback supplies, and most have published appnotes with a wealth of information.
    Find the names of a few chip manufacturers and search their sites for flyback chips - the numbers you find are the basis for the next stage of searches.
  14. Dodgydave
    Jun 22, 2012
    5,142
    768
    Uc3842/43/44/45 series,are used in most laptop and mobile phone chargers, these use flyback smps, salvage one from these to get you started, or an old atx psu.
    Application note AN1024 from international rectifier has information on transformers
  15. Colin55
    Member
    Aug 27, 2015
    204
    21
    Designing and building a fly-back circuit is much more complex than you think. The output voltage is nothing to do with turns-ratio and you have to know what you are doing.
    It's not for a beginner.
  16. ian field
    Oct 27, 2012
    4,447
    791
    When I repaired monitors, the 384x family were more common than all the others put together.
    You have to watch the last digit - they all have UVLO, 1 of each series are for direct off mains - I think the UVLO is around 16V, the other 2 are for automotive - for that I think the UVLO is about 9.5V. One of each series does up to 100% M/S ratio - the other 2 only do 50%.
    The MC34063 is a popular entry level control chip, it has an uncommitted output transistor so it can be a buck, a boost or an inverter.
  17. szhighstar
    Jun 26, 2012
    27
    5
    the core and bobbin are PQ type, these are common materials,do you have auxiliay winding? you cut off air gap on center leg of core.
