Turns on LED upon receiving IR signal
Discussion in 'The Projects Forum' started by DutCampos, Jul 2, 2014.
  1. DutCampos
    Jul 2, 2014
    Hi everyone, I'm working on what I think is a fairly simple project. However, I have no previous experience with electronics, so help would be greatly appreciated.
    I have to build two pairs of circuits: an IR transmitter and an IR receiver for each (let's call them pair A and pair B). The IR receiver needs to receive a signal from the transmitter and, upon receiving it, turn on a visible light LED (color doesn't really matter).
    The two catches are: 1) The pairs need to be "unique", meaning that Receiver A can't light up upon receivipng a signal from transmitter B (I think this means I need to modulate the transmitter's carrier frequency). And 2) I need them to be as small as I can possibly make it, especially the receiver.
    Here are some ideas, from what I've read:
    Feel free to disregard all of this if it's stupid or if you have a better idea!!
    a) The receiver would use something like this (https://www.sparkfun.com/datasheets/Sensors/Infrared/tsop382.pdf) of two different carrier frequencies. I would use that to light up a regular LED with a small button-cell battery.
    b) I could use this (https://www.sparkfun.com/datasheets/Components/SMD/DS1077.pdf) to modulate the carrier frequency on the transmitter, maybe?
    c) Build the receiver circuit on this protoboard (https://www.sparkfun.com/products/8886)
    Ask me if you have any questions and thank you for your help!
  2. Dodgydave
    Jun 22, 2012
    5,147
    769
    You need an encoder/ decoder chip to transmit data and receive data, using different codes set by links like the HT12D/E series, the VT pin 17 goes high on a valid signal.
    Setup circuits
    DutCampos likes this.
  3. Bernard
    Aug 7, 2008
    4,238
    414
    Are pairs free to roam about or they at a fixed distance & if so, at what distance? Is Pair A Tx, transmitter, physically attached to Pair B Rx, receiver.?
  4. DutCampos
    Jul 2, 2014
    Thank you for the help! What would I use the chip with? I mean, what component would actually receive the signal for the chip to decode?
    If you could also tell me what the complete circuit would look like, that would be amazing. But I know that is a ton of work, so if it's too much to ask, don't worry about it.
  5. DutCampos
    Jul 2, 2014
    The pairs are free to roam, but don't have to receive each other's signals at all times. If the receiver could light up when ~3 feet or less away from the transmitter, that'd be great.
    They are not connected physically.
  6. Dodgydave
    Jun 22, 2012
    5,147
    769
    use the infra red leds and receivers as you posted to send and receive.
  7. MrChips
    Oct 2, 2009
    12,625
    3,451
    IR transmitters and receivers operate at standard frequencies, for example, 38kHz.
    You don't alter the carrier frequency to make a unique transmitter/receiver pair.
    Instead, you encode and modulate the IR transmitted beam with a unique digital code using a microcontroller. The receiver does the opposite. It receives the digital code and checks for the unique code.
  8. DutCampos
    Jul 2, 2014
    Alright, got it! Thank you very much, all of you!
    Should I mark this thread as "solved" somehow? Or is that not done here?
  9. Bernard
    Aug 7, 2008
    4,238
    414
    Project information at about 25%.
    Check www.ROBOKITS.CO.IN , under " componets" they have downloads for HT12-A-E-D. The HT12A looks interesting as it can, with a 455kH resonator, output a 38 kHz signal ready to drive a LED driver. Price around US $ 2.60 ea or in rupies 70. It would be helpfull to see someones actual application.
    Is there any political limitation on angle of transmission or reception?
  10. MrChips
    Oct 2, 2009
    12,625
    3,451
  11. wayneh
    Sep 9, 2010
    12,379
    3,234
    We all appreciate feedback when a project works out, but that's generally the end of it. Of course some posters just disappear and we never know what happened. Not cool, because others coming along later cannot learn from the experiences of those that go before. You can "thank" individual posts when more words are unnecessary, kind of like a "+1".
  12. Bernard
    Aug 7, 2008
    4,238
    414
    Found the IC's at Newark element 14 for $1.37
  13. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Sounds like the most basic application for a couple of tiny cheap 8pin PIC chips and a few lines of code.
