Turn on,turn off -transistor
Discussion in 'General Electronics Chat' started by nileshkhupase, Jun 24, 2011.
  1. nileshkhupase
    Mar 22, 2011
    33
    :confused:
    what is turn on time, turn off time , Delay time,storage time in case of a transistor..?
    and if this information is not given in the data sheet how we can find out max. switching speed of that transistor?
    like i have data sheet of BC807 transistor..
    link for its data sheet is
    http://www.nxp.com/documents/data_sheet/BC807_BC807W_BC327.pdf
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You'd need to test samples of it in the circuit you intend to use it.
    That particular transistor has a transition frequency of 80MHz, which is kind of slow.
    If you put any transistor into deep saturation, it will take a lot longer to turn off than if you don't let it get deeply saturated.
