Turn On Time.
Discussion in 'Physics' started by BR-549, Jun 8, 2015.
  1. BR-549
    Sep 22, 2013
    2,184
    421
    I came across a most intriguing question the other day, and I would like to see what members here think.
    Setup for circuit.
    Perfect 12 VDC car battery. No internal resistance, constant voltage, any load.
    Perfect switch at battery.
    Perfect ammeters at terminals.
    Two perfect conductors, 1 light-year long.
    Perfect light bulb, resistive, 12 ohms, will not light until 1 amp.
    The light bulb can be slid any where around the 2 light year loop.
    Questions for light bulb at 1 light year(center of loop).
    1. After closing switch, when will bulb lite? Why?
    2. After closing switch, when does current start to flow and when does it reach maximum? Why?
    3. Are the currents equal at the same time?
    Now move bulb to negative terminal of battery.
    Repeat same 3 questions.
    Any thoughts?
    Slide the bulb out 1/2 light year on either conductor.
    Same questions. What do you surmise?
    Does voltage have to be established clear around the circuit before current flows.....or only across the circuit for current to flow?
  2. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Interesting scenario... I'm assuming that by "perfect" you mean superconducting components?
  3. BR-549
    Sep 22, 2013
    2,184
    421
    No, because we don't know all the properties of superconductors.
    By perfect I mean without resistance.
    Go ahead and assume no z too. In other words, assume the voltage can propagate at c.
  4. Kermit2
    Feb 5, 2010
    3,854
    968
    c used as a constant to represent the speed of light is customarily assumed to be "in vacuum". the speed of propagation through a metallic conductor, even one with no resistance to current flow, will not be the same speed as light in a vacuum. restate the question with a speed of propagation as a given so an answer can be formulated
  5. BR-549
    Sep 22, 2013
    2,184
    421
    I believe I have. Electricity can move at c thru these conductors. No Z or the Z of space, ok?
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,460
    792
    I'll throw a guess - the free electrons are where they are in the conductors, its rather different to turning on a tap into an empty hose and waiting for the water to arrive at the other end.
    However; there will be inertia - you shove a load of new electrons in one end and they have to repel the ones already there to make room.
    Might be worth asking the radio hams what velocity factor is all about.
  7. cmartinez
    Jan 17, 2007
    3,700
    2,802
    For starts... it it were perfect, as the OP is stating, the signal would travel at the speed of light. But then there would be a huge inductive load due to the wire's length, whose voltage wouldn't even begin to rise until after 2 years!
  8. BR-549
    Sep 22, 2013
    2,184
    421
    Sorry....Z means impedance.
  9. BR-549
    Sep 22, 2013
    2,184
    421
    There are no light year length conductors that I know of.
    I am pretending.
  10. ian field
    Oct 27, 2012
    4,460
    792
    Borg transwarp conduits.
    #12, BR-549 and cmartinez like this.
  11. cmartinez
    Jan 17, 2007
    3,700
    2,802
    :eek: but in this case... resistance is NOT futile... all we want is your willful cooperation :D
    #12 and BR-549 like this.
  12. joeyd999
    Jun 6, 2011
    2,759
    2,942
    In the first case, you are asking about the time between the activation of a switch and the subsequent illumination of a bulb 1 light year away. You do realize the the question of Simultaneity comes into play here, no? In fact, the timing of any two events will always be in question unless the two events occur at exactly the same position in 3d space.
    studiot likes this.
  13. ian field
    Oct 27, 2012
    4,460
    792
    Forming the conductors into a non-inductive configuration opens the possibility of folding it back so the bulb isn't far away.
  14. Kermit2
    Feb 5, 2010
    3,854
    968
    your constraints have rendered the question to be identical to the speed of photon propagation in empty space, the answer also becoming the same as such...the electrons, battery, lamp and conductor are no longer relevant points of difference to the exercise.
  15. Kermit2
    Feb 5, 2010
    3,854
    968
    the one I remember wrestling with was about a set of scissors. they are made of a rigid metal that cannot flex. they stretch from the earth to the sun and the blade end is four times as long as the handle end measured from the swivel point. if they are opened with velocity of 'c' measured at the handle end, what would the velocity of opening be at the other end?
  16. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Yes and no.... because although photons do not have mass... electrons do... and are therefore forbidden from traveling at exactly the speed of light... although they will get very close.
  17. Kermit2
    Feb 5, 2010
    3,854
    968
    i didnt say that .... he said that we should consider the velocity to be the same as 'c' in a follow up posting #5 in this thread... therefore it becomes identical to photon propagation.
  18. BR-549
    Sep 22, 2013
    2,184
    421
    hey guys.......it's just a DC circuit. Nothing more.
  19. cmartinez
    Jan 17, 2007
    3,700
    2,802
    So not only do we have perfect conductors and components... but also perfect electrons with no mass...
    maybe we should also include Alice and the Mad Hatter into this scenario?
  20. joeyd999
    Jun 6, 2011
    2,759
    2,942
    Don't forget the fruity-flavored rainbow-colored unicorn droppings.
