Turn momentary into toggle, use flip flop?
Discussion in 'The Projects Forum' started by NotVerySmart, Mar 20, 2011.
  1. NotVerySmart
    Mar 20, 2011
    I want to take the momentary circuit closure from a button switch and have it operate a toggle circuit. Press the button for on, press again for off. I've sort of looked into flip flops, is that the right way, or should I look into ICs? Also I would like it to start out in the off position if possible. Could somebody please explain how I could do this, obviously im not a pro, so make it simple:p
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. debjit625
    Apr 17, 2010
    790
    186
    Yes Flip-Flop can do it.... if you put both the inputs J and K to 1 (high) the outputs toggles when it is clocked.....for example something like this...
    I have used IC 74107 as it was in multisim,but you can use any flip-flop the effect will be the same....
    Good Luck
      File size:
      24.1 KB
      233
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    True if the requirment switches logic level signals. An alternate action PB switch will handle a much larger range of voltages and currents. The OP did not state what the switch is handling.
  5. NotVerySmart
    Mar 20, 2011
    Actually I guess I should of mentioned this, it's not actually a "button" that will be activating the toggle circuit, it will be a relay.
    This to be exact:2 ch momentary RF transmitter/receiver
    I want Relay1 to operate as a momentary circuit, but when I trigger Relay2 I want that circuit to stay on until I trigger it again, but you can only buy these things as all channels momentary or all channels toggle.
    Both the receiver and circuits activated by the relays will be 12v
  6. Bernard
    Aug 7, 2008
    4,233
    414
    Don't forget to de-bounce the switch or relay. A 555 as a 20 ms oneshot will do.
