tuner squeel
Discussion in 'Wireless & RF Design' started by PRS, Jan 31, 2010.
  1. PRS
    Aug 24, 2008
    989
    35
    What is causing those squeels when your near a station but not right on it?
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    With my HF radio equipment, I've often heard these pure oscillations when I tune through any of the bands. I believe that this is caused when people are tuning their radios. But this is HF, what frequency are you referring to?
    Austin
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    AM or FM? I'm betting AM. It has to do with sidebands being mixed (heterodyned) incorrectly.
  4. PRS
    Aug 24, 2008
    989
    35
    Electronerd, I think the squeel I'm talking about is common to most Am broadcast band radios. That's the frequency I am refering to. Also, commercial Am is the mode of modulation I am refering to.
  5. PRS
    Aug 24, 2008
    989
    35
    Bill, you're right, it's AM. But I'm not sure what you mean by incorrect mixing.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Think about how an AM dial is organized, every 10Khz there is a station, some far, some close. If you tune a dial between two stations their frequencies will heterodyne together, but not as a stable sound. Hence the squeal.
    Visualize two AM frequencies on a spectrum graph and you get the idea.
  7. PRS
    Aug 24, 2008
    989
    35
    Thanks. That makes sense.
