Tuned circuits
Discussion in 'General Electronics Chat' started by froten_140, Aug 5, 2008.
  1. froten_140
    Thread Starter Active Member
    Jun 4, 2006
    30
    Hello all,
    When designing a tuned RF amplifiers, a LC circuit is used in the input of the amplifier or as a load of its transistor collector. The L&C values for a certain frequency can be changed for the same rfrequency. For Example, for 4Mhz, we can use 1uH with 1583 pf, 10uH with 158 pf or another values.
    What is the values selection trick?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    What varies is the Q of the tank circuit. In most ocsillators I don't think it makes much difference, but for filters it determines the bandwidth.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  4. studiot
    Nov 9, 2007
    5,005
    515
    In any transistor circuit where the output is from the collector, the transistor wants to drive the same collector current, regardless of the impedance of the collector load. It takes the appropriate collector voltage to cause this to happen, allowing the rest of the supply to be dropped across the load.
    It follows that the higher the load impedance the higher the voltage dropped across it to maintain this state of affairs.
    Thus if we want to maximise the output voltage across the load we must maximise its impedance.
    Thus we go for as high value resistor as we can or use some special characteristic of another sub circuit to achieve high impedance.
    One method is to use current generators as active loads. this is often done in integrated circuits.
    However the tank circuit, comprising a parallel inductor and capacitor, has the very desirable characteristic of having its impedance vary with frequency, with a very pronounced maximum at the frequency of interest. So it will automatically 'tune' the overall voltage output (GAIN) of the circuit to this desired frequency.
    As to which combination of L and C, there is no magic. It just depends what you have that will minimise the resisitve element of the tnak. This is because the larger the ratio of the reactive impedance to the resistive (called circuit Q factor) the better.
    The series LC circuit, of course, has an impedance minimum at the frequency of interest.
  5. iamspook
    Member
    Aug 6, 2008
    27
    This becomes more critical as the frequency goes up.
    At some point, wires and traces connecting the components
    look like significant values in the calculation, and this is where
    careful spice analysis is best. But even before that, any lumped
    component considered ideal at low frequencies will actually
    have resistance, inductance and capacitive "flaws".
    For a coil, it has a reasonably measurable or calculable series
    resistance which will affect the Q factor. A capacitor will have
    an equivalent series resistance and leakage which will start to
    affect the circuit. As mentioned, when you take these into consideration,
    choose that which gives a desired result. This may be based
    on :
    * Cost
    * reliability
    * availability
    * physical size
    * ease of construction
    * temperature considerations
    * power handling
    etc
    If you don't care about some of the above or the influence of the
    flaws is insignificant, then there will be multiple suitable choices.
