Now for the "Math Rock of the Day" question,
Actually, it isn't quite that simple. (Well, not to me, anyway...)
I have a practical problem that I'd like to solve using stuff that I have.
Namely, some UGN-3130 Hall-effect sensors - coupled with bits of wire, ferrites, what have you - to determine when current through a circuit is above or below 2A, +/- 10%.
According to the datasheet, these little jewels trip when gauss is 175, and release when it is -175, within a certain temp range and all that stuff.
So, what I'm thinking is that I can establish a -175 static gauss bias on one side of the Hall-effect, and let it get overpowered on the other side by the desired 2A cutoff point.
Sure, I could buy a more modern Hall-effect sensor that could do all that for me. What's the fun in that?
Trouble is, I go searching for calculators for this kind of thing, and usually bump into formulas that include integrals, which make my eyes immediately glaze over - I'm not a calculus type of guy.
I'm thinking there has to be a relatively simple way to calculate Gauss from a coil (whether air or iron core) and then use the distance formula (btw, nobody has described the units in the searches I've done; distance squared vs field strength) in order to have a bias Gauss coil/electromagnet on one side of the sensor to keep it turned off, or have it turned on via a 2A current through a coil.
I hope this all makes sense. If you really want a schematic, say so.
