tube radio repair: HMV-1112
Discussion in 'General Electronics Chat' started by bug13, Mar 8, 2015.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    I got this radio from a second shop, it has been sitting in my garage from a while now. Now I have some ideas. My goal is using it as tube amplifier. (by passing the radio function)
    This radio is His Master's Voice - 1112, also called Marconiphone 919.
    Here is the schematic: http://www.radiomanuals.info/information/Broadcasters/sMarconi%20919.pdf
    So I found this faulty cap, what type of cap should I replace it with? It looks like C19 by matching the value and location, but I am not sure.
    Thanks guys!
  2. bug13
    Feb 13, 2012
    1,213
    38
    Forgot to ask:
    Is there any harmful chemical/substance in these old caps that I need to worry about? As the one needs replacing is popped open.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    It looks like the mentioned C19 is part of the tone control in combination with VR2.
    The value mentioned is 0.05 μF / 400 Volts.
    Nowerdays the normalized value would be 47 nF.
    As it is a foil capacitor, no dangerous fluids have been used (as they would have in electrolitic capacitors).
    Bertus
    bug13 and planeguy67 like this.
  4. flat5
    Nov 13, 2008
    403
    17
    Replace all the wax and paper caps that are in the audio chain (the circuits you are interested in).
    I would also remove the B+ from other stages not used. Don't trust these types of old caps.
    bug13 likes this.
  5. BReeves
    Member
    Nov 24, 2012
    412
    64
    rca6v6pp.jpg I wouldn't..
    That radio is an early AC/DC with no transformer. This means the chassis is connected to one side of the AC line. You hope it is the neutral side and should be if the power cord is polarized. Just fix the radio and enjoy it for what it is, if you want a tube amp build one, it isn't that hard.
    Here ya go, build this and you will be happier with the results.
    bug13 likes this.
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    AFAIK: those are just waxed paper - some of ye olde ancient electrolytics had some dodgy chemicals in them, but I used to pull them apart when I was a kid and I'm more than half-way to antique so far.
    bug13 likes this.
  7. bug13
    Feb 13, 2012
    1,213
    38
    So what is the green capacitor and the big cap behind the resistor? What type are they?
  8. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,314
    Mylar caps are good upgrade replacements for paper/foil types...
    In the interest of abatement of 'hot chassis' issues, it may be advisable to operate the device 'through' a 1:1 line-isolation transformer...
    Aroclors (polychlorinated biphenyl based potting compounds) were not deployed as dry (CIP wax) dielectric materials in that vintage/type of component...
    Despite the absence of polarity markings, the green-clad capacitor looks as if it may be electrolytic -- a better 'angle' is required for confident identification.
    Best Regards
    HP
    bug13 likes this.
  9. Dodgydave
    Jun 22, 2012
    5,150
    769
    They look like wax types, the green may be a polarized cap, need to know its location on the circuit,
    if your planning on using it as an amplifier, use the pick up terminals, but disconnect the radio signal feed first,by removing R15, looking at the circuit it has a transformer psu, if yours doesn't it will have a Live chassis.
    bug13 likes this.
  10. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,314
    FWIW I'd use a LIT in any event -- I've seen too many 'ground-faulted' power transformers in old sets (Can we say Crosley? ;))
    Best regards
    HP
    bug13 likes this.
  11. snav
    Aug 1, 2011
    100
    10
    I think I saw the filiment/hv/rect windings in the diagram he provided. Why do you say it's transformerless?
  12. debe
    Sep 21, 2010
    955
    185
    Because the original picture he has shown of the radio, it had no transformer but in its place were large wire wound resistors with adjustable taps. Typical of sets with no transformer. In those sets the valve filaments are all wired in series & a large resistor is used to control the filament voltage.
  13. Lundwall_Paul
    Oct 18, 2011
    222
    19
    By the way that cap is an electrolytic. The big black band tells me that.
  14. ian field
    Oct 27, 2012
    4,447
    791
    AFAICR: the big black band indicates which end is connected to the outer foil - if you peel the capacitor, you will eventually come to one of the 2 layers of foil - the one you get to first is connected to the lead at that end.
    In that era, the majority of electrolytics were chassis mounted, the polarity was marked with red and/or black paint dots on the solder lug rivets.
  15. BReeves
    Member
    Nov 24, 2012
    412
    64
    Because the schematic he linked to isn't for the radio he has.
    This has to be one of the first transformerless tube radios. Before they came out with the 35y4 and the other HV filament tubes to eliminate the need for the resistor. Thousands or maybe even millions of 5 tube AC/DC radios were sold based on that simple design.
  16. snav
    Aug 1, 2011
    100
    10
    Ah, Now I understand. Different post same subject.
  17. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    Thank you all for your concerns, I do understand the reason of your concerns, and the risk involves in a transformer-less psu.
    Please understand that:
    • I am repairing my old radio at work with my spare time. (there is at least another person with me while I am working on it)
    • There is an isolation transformer that I can use, if I need to test it.
    • All the power sockets are RCD protected.
    • I will NOT measure/poke/replace component live.
    Thanks again guys!
    PS: My radio is transformer-less, but the schematic (transformer version) linked above is the best I can find so far.
  18. ian field
    Oct 27, 2012
    4,447
    791
    In the UK; TV sets were mostly AC/DC dropper type from quite early on. Toward the end of that era, they realised they could dramatically reduce dissipation in the heater dropper by inserting a half-wave rectifier in the feed. Some of the first sets with solid state tuners used this fact to derive the 12V for the tuner, simply by having a 12V MOV (VDR in those days) as the bottom most element in the heater chain.
    This can be used to advantage if you have to piggy-back a WW resistor to replace a burned out section of heater dropper - apart from anything else, you can use a smaller/lower resistance.
    The only thing to watch for, is whether anything derives a low voltage AC supply from the bottom of the chain - I can't think of anything on a radio that would.
    bug13 likes this.
