tube amp, voltage regulation
bug13
Joined Feb 13, 2012
2,002
Hi guys
I was looking into a tube circuit the other day, they usually operates between 100 - 150 VDC, one thing I am curious about, why they don't use a high voltage regulator in vacuum tube amp?? Instead, they use some simple RC filter to filter the DC voltage.
alfacliff
Joined Dec 13, 2013
2,458
because the voltage supply isnt as critical in tube amps. a solid state amp with a 12 volt supply is a lot more critical for supply voltage because they start with so little and are current operated. the tupe amp starts with much higher voltage, so the actual voltage isnt as critical. some circuits such as oscilators and dc amps require regulation, but not most circuits.
For most receiver and power tube circuits the actual plate voltage was not critical and when it was required (in things like radar repeaters) most tube regulator circuits used shunt type regulators so they wasted power. I still have a few triode tube shunt regulator modules for high voltage bias supplies at work.
http://www.tubecad.com/july99/page12.html
