The arc-ing situation seems right...but...i would hear it...wouldn't I... well not while playing...and that is when it arcs...hmmm i just found an ot for a princeton deluxe from hammond...it is the output transformer thet that weber copied and sells in their kits for this amp.... anyway...i will resolder the whole thing ,try again with more atention to the ground...maybe i will star ground it this time...replace the sockets as well just to be shure...and...if it will act tje same, i'll put the money down for a hammond...but still one question...if it arced at some point...would it still workThe sneaky part is that a transformer that seems reasonable on an ohm meter can arc internally at several hundred volts. Measure all you want, but you will still need experience and intuition to develop the courage to bin a $50 transformer just because you can't find anything else wrong.
No. If it arced, the carbon path is established and it will not heal itself. The proof is in the output sound, so you can hear it, but you have to know what you're listening for, and that requires experience that resembles wisdom. A real pro would know in a few seconds. An amateur might fuss with it until he gives up and never gets it right.if it arced at some point...would it still work
Sorry to be disagreeable, but, "dropped quite a lot of volume and clarity...overnight" is one definition of, "failed" or, "doesn't work properly".so... you said it wouldn' t work anymore... but mine does...it just dropped a lot of volume and clarity...and... it happened over night...
by Jeff Child
by Aaron Carman
by Jake Hertz
