TTL
WBahn
Joined Mar 31, 2012
30,077
Since this is YOUR homework, how about offering up YOUR suggestions and we can provide feedback and comments about them.
WBahn
Joined Mar 31, 2012
30,077
In 1970 they may have had advantages over the competitive products which were RTL and DTL, but now maybe not so much.
The main uses today are for doing wired-OR and wired-AND logic (you see this a LOT in IC circuits, less so in discrete designs) and the ability to do some degree of level shifting by acting as a low-side switch.
dtekumse
Joined Dec 15, 2015
9
Well, since you guys already did all the work, as crutschow noticed, maybe I can (mis)use this thread for a bit of off-topic (if off-topic is possible to a thread titled "TTL").
Where did you study these circuits, I mean at what level of education? If University, which one and when? And, in general, what is your experience, to what extent this logic family is studied these days?
I just started as a teaching assistant at a Faculty and I am interested to see what others do. Maybe this will not be completely off-topic if I ask our student here, md yasir, where did he get the assignment from?
Papabravo
Joined Feb 24, 2006
21,227
That's not really much of an answer.
@dtekumse
I received a Master's degree in Electrical Engineering from the University of Michigan in 1970. I first encountered TTL chips on the job after graduation. DEC computers of that era were still built with discrete DTL and I was familiar them from my part time summer work. Three years later RCA and National introduced CMOS, which although kinda slow at the time had great promise for low power circuits. Going forward I don't see much utility in SSI and MSI logic other than the education market.
KL7AJ
Joined Nov 4, 2008
2,229
what are the advantages of open collector TTL
Open collector TTL allows you to drive a physical device that uses some current, such as a relay or lamp. The external device acts as the "pull up" for the output stage.
So-called "lamp driver" TTL chips are VERY expensive for some reason (I know...we just had to replace a bunch of them where I work), so I usually use an external open collector transistor.
Hope this helps,
Eric
Papabravo
Joined Feb 24, 2006
21,227
I believe you can still buy specific TTL circuits with an open collector output as shown in this listing here.
The original question was about advantages. My response was about the lack of advantages not the lack of available parts. They'll be on the grey market for at least another decade by which time their lifetime will have exceeded half a century.
34,466
Apparently I misunderstood. :oops:
When you stated "there aren't any anymore" was the answer the professor was looking for, I thought you meant that TTL devices with an open collector output were no longer available.
