I attempted to post earlier but experienced trouble with my schematic. Being a site newbie is erksome at times. Anyway, I have studied from All About Circuits the TTL NOT Gate, the TTL NAND/AND Gates, and the TTL NOR/OR Gates. AAC has wonderful theories of circuit operation when it comes to these circuits. Howbeit, the link below takes you to my circuit in question. It is the 2 input TTL XOR Logic Gate Circuit: (oh, it is the IC 7486, 14 pin package, Exclusive OR Gate, if that data helps).
http://www.interfacebus.com/ic-exclusive-or-gate-dual-input-dip.html
In my earlier attempt to post I tried to copy and paste the circuit here...but that failed. So, hopefully the provided link will be of use.
Now, due to the depth of explanations on the aforementioned AAC topics (that is, TTL NOT, TTL NAND, etc.), I can see that the far left of the circuit is the usual right and left steering diodes. Also, due to the AAC prior lessons, I can discern that the far right of the schematic is the totem pole output section of the circuit (instead of the open collector variety). Howbeit, the in-between stuff has me completely lost. Could someone provide me with the depth of circuit explanation for this TTL XOR Gate as I encountered from the prior topics? Thanks.
