TTL to DC motor
Discussion in 'General Electronics Chat' started by studentstudent, Apr 7, 2009.
  1. studentstudent
    Apr 7, 2009
    thanks for help and now I can control my motor speed by PWM
  2. mbohuntr
    Apr 6, 2009
    413
    32
    A very general question,Regulated voltage means you never exceed that "pegged" voltage. I think you are looking for remote control of relays. You may wish to spend some time at play-hookey.com. A good start if your just getting into it.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Consider using a ULN2003 or ULN2803 if you have several loads to drive. These are peripheral driver IC's that contain seven or eight Darlington pairs respectively, and can sink up to 500mA current per channel.
    If you'd like to build an H-bridge for reversible motors, here's a page that you'll find helpful:
    http://www.solarbotics.net/library/circuits/driver_4varHbridge.html
    There are several other ideas available via the links on the left.
