I am working on a project in lab, and need to connect two devices.
One produces a ttl-compatible waveform square wave (0, 5 volts). The device to receive it is cmos, and cannot take 5 volts. the HIGH it wants must be at least 3.3 volts.
Inside of the receiving device is a pull up 3.3kOhm resistor to 3.3 volts. What must I do to connect these devices successfully?
Thank you!
Thank you!
