TTL Logic help needed
Discussion in 'The Projects Forum' started by Phiplex, May 3, 2009.
  1. Phiplex
    May 3, 2009
    Need help designing TTL logic for attached timing diagram.
    First edge of Input A signal should always trigger the output high (=1).
    The second (and not the first) edge of Input B signal (during output = 1) should lower the output again (=0). Please help !
  2. Ron H
    Apr 14, 2005
    7,050
    657
    This worked when I simulated it.
  3. Phiplex
    May 3, 2009
    Thank you very very much, Ron. You made my day :D /Phiplex
