It's not the current that you worry about, but the voltage. If the '109 sees more than 5.5 volts on an input, it will probably fail. TTL is very sensitive to voltage limits.Is controlling the supply current of each IC enough to protect the flip flop from the output signal of the timers?
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Aaron Carman
