TTL CookBook
Discussion in 'Electronics Resources' started by Interfacer, Dec 15, 2012.
  1. Interfacer
    Dec 15, 2012
    9
    Hi all. First Post! Does anyone know where I can find a comprehensive TTL Cook Book (Particularly interested in a chip called 555 Timer and I want to understand its capabilities)? Also looking for any workbench software (not sure exactly what it's called but allows you to design and simulate circuits with some built-in chips too). I bought a breadboard that came with a free disk with this software but I lost it. I like to gain practical insight while I study, which is also why I joined this forum, but my breadboard and the components I have have limitations when it comes to some topics. Thanks in advance.
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Sure. Hang around this website a bit longer and you will find answers to all of your questions.
  3. spinnaker
    Oct 29, 2009
    5,062
    1,160
    I had the TTL Cookbook in my possession that is probably 30 years old. :)
    Sadly it has gone missing. :( Hopefully it is around here somewhere.
    My TV Typewriter Cookbook is still here.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  5. atferrari
    Jan 6, 2004
    2,663
    783
  6. ScottWang
    Aug 23, 2012
    4,924
    777
    absf, thatoneguy and bertus like this.
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  8. crutschow
    Mar 14, 2008
    13,469
    3,356
    The circuit simulation software commonly used on these sites is LTspice which is free from Linear Technology. There is a fairly steep learning curve but it is worth the effort to learn if you want to study electronic circuits. It's a lot easier and faster to simulate circuits then to breadboard them. And you will have a greater assurance that the circuit will work if you do build it.
    There is an Electronics Workbench circuit simulator that can be purchased from National Instruments, which is a good simulator but it's a bit pricey for home use unless you qualify for the student version.
  9. ScottWang
    Aug 23, 2012
    4,924
    777
  10. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    I know the EDUCYPEDIA site is not as stable as the AAC, but it seems to be working again.
    Bertus
  11. ScottWang
    Aug 23, 2012
    4,924
    777
    Thanks, your are right.
    I tried many times, but I can't connect to, and then I just tried again, I can visit the site.
