TTL Circuit
Discussion in 'Homework Help' started by wiz0r, Aug 14, 2010.
  1. wiz0r
    Thread Starter Active Member
    May 2, 2008
    64
    The questions has been solved!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The two transistors with double emitters are the inputs. Look at what they do when all four emitters are at a high level. And then when one or all gets pulled low. The transistors are set up as switches.
    You have a fixed voltage supply and values for the resistors, so power is easy to calculate (don't forget the PN junction drops).
  3. wiz0r
    May 2, 2008
    64
    I got it, thank you very much, beenthere. I'm too tired to write the solution, so I'll skip it.
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    It is NOT nice to remove the question.
    That way others with the same problem don't have a clue of this thread.
    This forum is to learn from each other.
    Bertus
