trying to use a transistor controlled by ntc 15k to switch on a relay
Discussion in 'General Electronics Chat' started by roadey_carl, Apr 4, 2010.
  1. roadey_carl
    Thread Starter Active Member
    Jun 5, 2009
    116
    5
    Hey folks, Im trying to get a transistor to switch on a relay. the transistor is controlled by a 15k ntc. It works ok but as the risistance slowley decreases it triggers the coil in the relay very slowley so the contacts have a high resistance between them untill the ntc havs a small enough resistance to alow the foward voltage on the transistor to be full flow rate. Is there any way I can get it so the relay just works as on/off when it gets to a certian risistance? maybe some kind of regulator?
    Im a bit of a newbie with electronics so cheers for any help!:)
    Carl
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you post a schematic of the circuit you are using so that we can have a look?
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sounds like a voltage comparator would work.
  4. roadey_carl
    Jun 5, 2009
    116
    5
  5. kkazem
    Jul 23, 2009
    160
    28
    What you need is to dump the transistor ckt and replace it with a single-supply comparator circuit with hysteresis to make the relay snap-on. These ICs are inexpensive and easy to use. I recommend the LM393CN. Also, unless you want to blow-up your transistor switch, you need a diode (a run-of-the-mill 1N4004 or similar will do fine) across the relay coil to prevent the coil inductance from generating a voltage that will breakdown your transistor and it works the same if you use a comparator. If you a google search for comparator relay driver circuits you'll find many. Also, the TI website (www.ti.com) is another great source of application notes on op-amp and comparator designs. You may not even need the hysteresis (positive feedback), but it only adds 2 or 3 small resistors to the ckt.
    Regards,
    Kamran Kazem
  6. roadey_carl
    Jun 5, 2009
    116
    5
    Thanks alot kkazem, you are a true legend!! I have no idea what hystereresis but I will have a read up about it and see if I'll find it any use to me!
    Thanks again thats been a real help :D
  7. Jony130
    Feb 17, 2009
    3,993
    1,116
    You can use one of those classic Schmitt trigger diagrams.
      File size:
      6.8 KB
      57
      File size:
      15 KB
      64
  8. roadey_carl
    Jun 5, 2009
    116
    5
    Hey, I have fallen in love with the LM393N, what an awsome chip!! I just wonderd.... what is the "inverting" and "Non-inverting" all about? I've made the circuit I needed to make, but was just curious about what that ment?
