trying to understand op-amp circuits
Discussion in 'General Electronics Chat' started by TL314, Apr 6, 2015.
  1. TL314
    Mar 29, 2015
    The unity gain op-amp circuit seems simple, but what use is the amp if it only provides a copy if the input? Why couldn't we just use a wire to connect the source (input) to its load (output) since its just the same? Vin=Vout?
    Confused o_O
  2. cornishlad
    Jul 31, 2013
    The input impedance will be high and the ouput impedance low. So there is power gain avalable.
    Hypatia's Protege, TL314 and Mike33 like this.
  3. Mike33
    Feb 4, 2005
    It's known as a 'buffer', and it amplifies CURRENT rather than if you need to drive something with a low input impedance, which would objectionably load down the circuit which precedes it, you can use a buffer to isolate it from that loading...
    mossman, Hypatia's Protege and TL314 like this.
