trying to repair my car radio, need some help identifying a surface mount component
Discussion in 'General Electronics Chat' started by sedemdeh, Oct 8, 2007.
  1. sedemdeh
    Nov 18, 2004
    11
    my camera is busted but I not sure if I could have gotten a clear pic anyway..
    the component in question has the markings as displayed in the pic..
    I'm not sure if its a transistor or something else and I've tried to search but I don't have much to go on..
    any help would be great, I just need to find something comparable
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    It is an SMD component, but I can't really guess what it is. Besides the markings, can you see any sequence of characters?
  3. sedemdeh
    Nov 18, 2004
    11
    that is all that was on it, nothing else
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The package could be for an SMT transistor, but there is no way to tell what polarity or kind from the illo.
  5. sedemdeh
    Nov 18, 2004
    11
    the circuit controls the lcd display on the radio. the leg on the side that looks like a Q is positive, and I can get the display to work by jumping that positive leg to the center leg..
    My problem is that when that is done the radio draw more current even when turned off and could possibly drain the battery..
  6. lightingman
    Apr 19, 2007
    374
    22
    This device, as far as I can tell is an MMBT5088 If the marking is 1Q. NPN, vce = 30v.Hope this helps.....Daniel.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    good call on lightingman's part.
    If you can't find an MMBT5088, you might be able to use a 2N5088; that's the same transistor in a TO-92 case. I had to do that when I was visiting my folks in July for a week; couldn't find a SMT version of a 2n3904 to fix their cordless phone locally, and didn't have time to wait for one to be delivered. Took some careful lead bending and trimming to make it work, but work it did.
  8. cumesoftware
    Apr 27, 2007
    1,330
    11
    You are the man!:D
    Now serioulsly, you can you tell exacly the type of the trnsistor by readind the marking "1Q"? Is there a table for these markings?
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There are quite a few tables out there. In the past, standardization of markings was a huge problem, but it's getting better.
    Here is a very useful site:
    http://www.educypedia.be/electronics/datacomponent.htm
    You'll still have "rummaging around" to do, but at least you'll have lots of stuff to look at ;)
    One of the really nice things about that site is that it'll give non-ROHS compliant equivalents (that is, parts that may contain lead and other elements heinous to the environment) if available - very handy for those with well-seasoned "treasure boxes"
    For example, a quick check shows that MPSA18 is a non-ROHS compliant but otherwise equivalent replacement for the OP's part.
  10. lightingman
    Apr 19, 2007
    374
    22
  11. sedemdeh
    Nov 18, 2004
    11
    thanks for all the assistance guys, hopefully I can get this radio working properly again
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Nah, you didn't cheat.
    85% of the battle is just knowing where in the heck to look something up! ;)
  13. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The other 15% is remembering where I put that darn whatsis!!
  14. sedemdeh
    Nov 18, 2004
    11
    ok where can I get this thing without paying for 50-100 (2N5088 that is)
  15. cumesoftware
    Apr 27, 2007
    1,330
    11
    Very good resource! You should put this in the "Electronic Resources" section, if you didn't.
    I can't open the link! I think it is malformed. I think this is the link:
    www.tkb-4u.com/code/smdcode/indexsmdcode.php
    Everyone cheats, but of course, some cheat more (like Bill MS).
  16. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Try online auctions. The big one has at least three vendors currently offering 2N5088s.
  17. mtwire
    Jun 26, 2008
