Hello community,
I'm working on my school project and therefor as the title says I'm trying to read data from the MMA7660 accelerometer with an LPC1343 over I2C connection.
The project is about reading out the data of accelerometer and show the values with LEDs so that the uC-Board works as a level.
I have everything configured as said in the data sheet and I also make the process for reading data over I2C (STA-Bit -> address... and so on).
When I want to try it out the program is always stocked in the second while after sending the slave address of the accelerometer.
Don't wonder, I use some of the LEDs for debugging
I recognized that the status-byte after sending the slave address is 0... but thats not good...
Can anyone of you help me out her?
Thanks a lot!
Here is the code:
Thanks a lot!
Here is the code:
Rich (BB code):
* file Wasserwaage_LPC_1343
* author Patrick Gröller
* brief program the accelerator to show tha g-status with LEDs
* date 19-05-2014
//Accelerator slave adress = 0x4C
#include <LPC13xx.h>
#include <type.h>
#define LATCH_EN (1<<2)
#define LED1 (1<<4) /* PIO1_4 */
#define LED2 (1<<5) /* PIO1_5 */
#define LED3 (1<<6) /* PIO1_6 */
#define LED4 (1<<7) /* PIO1_7 */
#define LED5 (1<<8) /* PIO1_8 */
#define LED6 (1<<9) /* PIO1_9 */
#define LED7 (1<<10) /* PIO1_10 */
#define LED8 (1<<11) /* PIO1_11 */
#define LED_GREEN_ENB (1<<0)
#define LED_RED_EN (1<<2)
#define MMA7660_DevAdr 0x4C
#define MMA7660_XValue 0x00
volatile uint8_t I2CMasterBuffer[7];
void blinkDebug(int blinkanz, unsigned char LEDMask)
int i, cnt;
for (i=0; i<blinkanz; i++)
LPC_GPIO1->DATA |= LEDMask;
for(cnt=0;cnt<=3000000;cnt++);
LPC_GPIO1->DATA &= ~LEDMask;
void LED_Config(void)
SystemInit(); /* Initialize clocks */
LPC_IOCON->JTAG_nTRST_PIO1_2 |= (1<<0); /* configure LED_RED_EN as IO pin */
/* configure the direction of several IO pins */
LPC_GPIO3->DIR = LATCH_EN;
LPC_GPIO1->DIR = (LED_RED_EN | LED1 | LED2 | LED3 | LED4 | LED5 | LED6 | LED7 | LED8);
LPC_GPIO2->DIR = LED_GREEN_ENB;
LPC_GPIO3->DATA = LATCH_EN; /* enable the Latch */
//LPC_GPIO2->DATA &= ~(LED_GREEN_ENB); /* disable the Green LEDs - low active */
LPC_GPIO1->DATA |= (LED_RED_EN); /* enable the Red LEDs - high active */
/* all other LEDs -> off */
LPC_GPIO1->DATA &= ~(LED1 | LED2 | LED3 | LED4 | LED5 | LED6 | LED7 | LED8);
blinkDebug(3, 0x010); //DEBUG
void I2C_Init(void)
LPC_IOCON->PIO0_4 |= 0x00000001;
LPC_IOCON->PIO0_5 |= 0x00000001;
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<5); //Clock enable for I2C
LPC_SYSCON->PRESETCTRL |= (1<<1); //de-asserts reset signal to I2C
LPC_I2C->CONCLR = (1<<2); /* Assert acknowledge Clear bit */
LPC_I2C->CONCLR = (1<<3); /* I2C interrupt Clear bit */
LPC_I2C->CONCLR = (1<<5); /* START flag clear */
LPC_I2C->CONSET = (1<<6); /* I2C enable */
blinkDebug(3, 0x020); //DEBUG
unsigned char readData_I2C(unsigned char addr, unsigned reg, unsigned data)
int cnt;
//MASTER transmitter mode
LPC_I2C->CONSET |= (1<<5); /* START condition */
LPC_GPIO1->DATA |= LED8; //DEBUG
for(cnt=0;cnt<=5000000;cnt++); //DEBUG
while(!(LPC_I2C->CONSET & (1<<3))); /* wait for SI Bit, till bus is free */
if (LPC_I2C->STAT != 0x08) /* Status 0x08 bedeutet START condiction empfangen*/
return 11; /* FALSE */
LPC_GPIO1->DATA &= ~LED8; //DEBUG
LPC_I2C->CONCLR = (1<<3); /* Set SIC Bit for clearing SI in CONSET */
LPC_I2C->DAT = (addr<<1); /* slave address + 8. bit = 0 (8. Bit ist für R=1/W=0)*/
LPC_GPIO1->DATA |= LED7; //DEBUG
while(!(LPC_I2C->CONSET & (1<<3))); /* wait for interrupt (ACK Adresse + Write) */
if (LPC_I2C->STAT != 0x01) /* Status 0x18 bedeutet Slave-Address + W empfangen!*/
LPC_GPIO1->DATA |= ((LPC_I2C->STAT)<<1); //DEBUG
return 22;/* FALSE */
LPC_GPIO1->DATA &= ~LED7; //DEBUG
LPC_I2C->DAT = reg ; /* register address*/
LPC_GPIO1->DATA |= LED6; //DEBUG
while(!(LPC_I2C->CONSET & (1<<3))); /* wait for SI Bit */
if (LPC_I2C->STAT != 0x28) /* möglicher Status code:*/
return 33;/* FALSE */ /* 0x28 Data + ACK recieved*/
/* 0x30 Data NOT ACK recieved*/
LPC_GPIO1->DATA &= ~LED6; //DEBUG
LPC_I2C->CONSET |= (1<<5); /* Repeated START condition */
LPC_GPIO1->DATA |= LED5; //DEBUG
if (LPC_I2C->STAT != 0x10) /* Status 0x08 bedeutet START condiction empfangen*/
return 44; /* FALSE */
LPC_GPIO1->DATA &= ~LED5; //DEBUG
LPC_I2C->DAT = (addr<<1)+1 ; /* slave address + 8. bit = 1 (8. Bit ist für R=1/W=0)*/
LPC_GPIO1->DATA |= LED4; //DEBUG
while(!(LPC_I2C->CONSET & (1<<3))); /* wait for SI Bit (ACK Adresse + Write) */
if (LPC_I2C->STAT != 0x18) /* möglicher Status code:*/
return 55;/* FALSE */ /* 0x40 SLA+R and ACK recieved*/
/* 0x48 SLA+R and no ACK recieved*/
LPC_GPIO1->DATA &= ~LED4; //DEBUG
data = LPC_I2C->DAT;
LPC_I2C->CONSET |= (1<<4); /* STOP ausgeben */
return 0;
void I2C_IRQHandler(void){
int i = 0;
i++;
uint8_t I2C_state;
I2C_state = LPC_I2C->STAT; /* recent state */
switch (I2C_state) {
case 0x08: /* a start condition is issued */
LPC_I2C->DAT = I2CMasterBuffer[0];
LPC_I2C->CONCLR = (1<<3) | (1<<5); //interrupt clear bit & START flag clear bit
break;
default:
LPC_I2C->CONCLR = (1<<3); //Interrupt clear bit
break;
int main (void)
LED_Config();
I2C_Init();
unsigned char sensorValue = 0;
unsigned char I2C_Stat;
while(1)
I2C_Stat = readData_I2C(MMA7660_DevAdr, MMA7660_XValue, sensorValue);
if(I2C_Stat == 0 && sensorValue > 0)
LPC_GPIO1->DATA |= (LED1 | LED2);
//else
// LPC_GPIO1->DATA |= (LED7 | LED8 | LED5);
