Trying to make my bike safer
Discussion in 'The Projects Forum' started by Printz, Oct 2, 2010.
Thread Status:
Not open for further replies.
  1. Printz
    Oct 2, 2010
    31
    I want to make an LED taillight for scooter. I found the LED's I plan on using and I'm working on the board now. I have been doing a bunch f searching and have kinda decided on using a 555 timer with a 4017 for the output. My goal for the light is to be a tail light with running lights, and a brighter brake light. I also want to use half of the array, each side, to be progressively lit blinkers. So the lights turn on from the center out to indicate the direction. I would really appreciate any help with this, it's been a few years since I've built a circuit from the board up.
    Mitchell
  2. wayneh
    Sep 9, 2010
    12,379
    3,232
    Can you post a diagram of what you're thinking of? Also, if this application was automotive I think it'd be against forum rules to help. Safety first. Maybe bicycles don't count.
    You can buy cheap lights that do what you're describing, except I've never seen a bike light that indicates braking. That'd be a great idea, but of course you'd have to create a signal to indicate that the brakes ate applied.
  3. Printz
    Oct 2, 2010
    31
    It's not really automotive as much my scooter. It's a Chinese scooter, so no one makes a taillight that does what I'm trying to do. The only things close have been custom made.
    I can't really post a diagram right now; I'll work on it though. The plan so far is to do 16 columns of 4 LEDs. Split 8 and 8,the two halves will progressively light in sequence to indicate direction. (make sense?) The whole array should operate as a standard drive/brake light when not engaged as blinkers.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    As the scooter is motorized, modifications to the lighting/turn signals are covered by our guidelines:
    Printz likes this.
Thread Status:
