Questions:
1) Am I correct to assume the batteries are being charged relying only in that 30ohm resistor to limit the current?
2) Is 12V a correct voltage to charge the batteries? The power supply that was given to me does not have the Hoover brand, might have been used incorrectly.
3)Should I make a small constant current charger with an LM317 instead?
4)How can I try these batteries for health?
The vacuum was given to me and I was told it holds no charge. It came with a 12V, 1A DC power supply that was being used to charge it.
I opened it up and the 3x AAA measure close to 3.6V at the terminals, although they go down close to Zero when I turn the switch ON.
There is a visible burn mark near the resistor. It looks like a 2W and measures 30ohm.
I tried to interpret the circuit and simulated it on Falstad. There is something odd in the way the LED is mounted on the pcb but it lights up when the 12V power supply is plugged in (the LED is OFF when the switch is changed to turn the motor ON).
http://tinyurl.com/hd4e24h (there is a diagram attached)
