Trying to identify small elec part
erik_n
Joined Sep 13, 2016
5
Greetings folks.
I'm attempting to repair an item and need to replace this conductive springy-looking thing.
Tough to do without knowing what it's called. I just need the spring part, but I attached a picture of it mounted on the conductive post thingy that it slides onto. Sorry for all the non-technical jargon. Thanks!
erik_n
Joined Sep 13, 2016
5
I'm basically just looking for the name of the part, but if you can point me in the direction of where I could find it, that would be unexpectedly helpful. Thanks again!
erik_n
Joined Sep 13, 2016
5
Well, because it's part of an assembly that carries a current coupled, and the fact that I can't just stick any spring in there, I guess I figured there's a more descriptive name for it.
If you look at the first picture, the black wire coming in from the back powers the spring, which makes contact with a conductive track on a rotor on a wheel hub. Is there a name for that whole assembly?
AlbertHall
Joined Jun 4, 2014
12,347
What's wrong with the one you have got? Did it originally have a ball bearing on the end of it which has fallen out?
You would have to replace it with a spring with the same dimensions and spring rate *how stiff it is).
I still see nothing which makes it other than just a spring.
#12
Joined Nov 30, 2010
18,224
It's called a, "spring". Look up the make and model of the thing it goes in. Get a parts drawing from the manufacturer. Order the thingy. You will know which one to order because the parts list will say, "spring".
erik_n
Joined Sep 13, 2016
5
No, the one pictured is from the other side of the rotor. I need 2 to complete the circuit.
But it would also have to be made of something conductive, right? I imagine it's not something that would be stocked with the springs/connectors at a chain hardware store.
erik_n
Joined Sep 13, 2016
5
The manufacturer is the first place I tried. It's a dead end, Thanks though.
AlbertHall
Joined Jun 4, 2014
12,347
The vast majority of springs are made of metal. Metals conduct electricity.
Alec_t
Joined Sep 17, 2013
14,333
Any bog standard spring of similar dimensions (or cut down from a longer spring) will probably do. It doesn't look as though it's capable of carrying much current, so I doubt it matters exactly what it's made from (unless it's in a damp/wet environment requiring a corrosion-proof finish).
hp1729
Joined Nov 23, 2015
2,304
Greetings folks.
View attachment 111923 View attachment 111924
Wow! Good camera! Where do you live? Is there a lot of manufacturing in your area. Is there a spring manufacturer or distributor? Take dimensions and wire thickness and force to move it down to them or the Internet.
ian field
Joined Oct 27, 2012
6,536
What makes it not just a spring?
Not much - it may have plating optimised for electrical conductivity rather than corrosion resistance.
If they were *THAT* worried about conductivity, they'd go for gold or silver plating - silver is easy to identify when it blackens with exposure to air.
