here's a pic of the cable: http://img121.imageshack.us/img121/5677/cimg0155d.jpgThe Best Solution is if u don't use the CD changer, to use it's Audio inputs.
So Assemble the set and I will Explain how u shud go abt it, since we have photo's this can be easy.
Try to get Ur hands on an good Quality Audio cable the has a jack tht could connect to Ur MP3 player or whatever that u are trying to connect.
Show the cable. I'll tell u where to connect
the ground is not woven around the conductor, but just sitting parallel to it...i thinkIs the ground sheilding completely woven around the inner conductor. If not U will have ignition interference.
U cannot use head phone cables. they are not woven, atleast not most of them
Try better quality ones. Flexible ones. Otherwise u might have to renew them from time to time.
I gtg out, be back in an hr or so
Tell him to get his fact straight, and not to brag about things he clearly has no idea on.i asked some guy (who is an audiophile) and he said in practice there is no difference between woven cable and parallel...
I'm gonna do it in a bit and report back.U need to tell me how the unit respond when u switch to CD mode without the changer unit.
Does show CD changer error of any sort?
Your CD changer has both anolg and digital communication with radio unit. So if you disconnect the CD unit. You will not be able to select CD changer as input unit. It is that simple. It could be as simple as pin that get a high or low level. If a CD unit is onboard. Or worse it is built in the digital communication process between the CD unit and the main audio unit.so i connected the cd changer and turned it on, it played the cd that was in it.
then i turned the stereo off.
disconnected the cd changer.
turned on the stereo
display said "CD EEE"
I looked up the error in car manual and it said "misconnection or disconnection of CD changer"
The CD changer is an independent unit. It is not attached to the car or the stereo.
here's a pic of the front panel: http://img209.imageshack.us/img209/5020/photowe.jpg
btw, that's the cd changer under the stereo
by Duane Benson
by Aaron Carman
by Jake Hertz
by Duane Benson
