Trying to find a realistic idea of what brightness of LEDs is reasonable
Discussion in 'General Electronics Chat' started by seanspotatobusiness, Sep 29, 2016.
  1. seanspotatobusiness
    Sep 17, 2016
    32
    When I'm looking at LEDs for sale, it seems to me that some sellers give unrealistic specifications regarding their LEDs' brightness. I was hoping someone could point me in the direction of a resource that would give me the ability to determine when sellers are blatantly lying, so I can avoid buying from them.
    What are realistic brightnesses for different sizes (e.g. 3mm, 5mm, 10mm), colours and If currents/powers of LEDs? Would you expect a different brightness between 3mm and 5mm LEDs if they both have the same Vf and If?
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    OBW0549 likes this.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    What is your application?
    There are several brightness categories for LEDs, but mainly standard and ultrabright with one or more brightness buckets each.
    Different sizes will have different perceived brightnesses because the package is designed to disperse light. You also have to consider viewing angle and distance.
    If you require a certain brightness in multiple LEDs, you need to drive them with current sources. That minimizes the impact of forward voltage variations. Brightness matching will require using LEDs from the same lot that have perhaps been sorted by brightness by the manufacturer.
  4. KJ6EAD
    Apr 30, 2011
    1,426
    364
    Cree and Nichia as well as the aforementioned Kingbright are reputable.
    It would be nice if manufacturers would give a lumen rating instead of candella, millicandella, wattage, etc.
  5. hp1729
    Nov 23, 2015
    2,105
    235
    Reference the data sheets instead of the salesperson.
    Yes, consistency between manufacturers would be nice.
    Brightness just depends on so many factors. Incandescent lights, or LEDs for general room lighting, put out light in all directions. LEDs usually just put out light in one direction and not with the same angle. Some in a 30 degree cone. Some in 120 degree. You have to compare all specs.
  6. DickCappels
    Aug 21, 2008
    2,779
    674
