Trying to find 120 mohm Resistor PLEASE HELP
Status
Not open for further replies.
Ripley Rocks
Joined Nov 6, 2015
Hello all,
I am trying to find a resistor for a guitar amplifier head that I have. The resistor got broken while going through some other things. The color on the resistor is BROWN, RED, VIOLET, SILVER which I looked up to be 120 mOhm 10%. I have looked high and low and far and wide online but haven't been able to find where I can get one. Can anyone help me find a place to get this?
bertus
Joined Apr 5, 2008
22,276
It would be nice to know in wich country you are.
That way we could give you a more localized advice.
Did you have a look at the big companies like Farnell / Newark, Mouser and Digi-key?
Bertus
bertus
Joined Apr 5, 2008
22,276
When a 10% resistor is used, the circuit would work fine with a 5% resistor as the tolerance is within the limits.
Bertus
That should be 12 + 7 zeros 10%=silver
120,000,000
Which makes it 120 Megohms
m is milli; 1E3
M is meg 1E6
which is quite high. 120 Meg ohm's is probably not in the range of most multimeter to be able to measure.
Sometimes colors are not clear.
bertus
Joined Apr 5, 2008
22,276
Do you have the schematic where the resistor is used?
As KISS already said, the colors can be difficult.
A 120 Mega Ohms resistor is not very often used.
Bertus
Alec_t
Joined Sep 17, 2013
14,313
120 megohms seems an unusually high value? You will have to take great care in mounting it, otherwise leakage conductance via the support or air humidity could drastically reduce its effective value.
#12
Joined Nov 30, 2010
18,224
Very not likely that the real value is 120 Meg. Probably a color distorted by heat.
Photo, please...or a brand name or a model number or the country you're in...
Status
