Trying to figure out if i can exceed Amps by a factor of 3.4A
Discussion in 'The Projects Forum' started by jermyc, Feb 24, 2016.
  1. jermyc
    Feb 24, 2016
    8
    I have a project that i am working on, i am new to electronics and i am committed to figuring this out. My problem is my diagram that i got created rated my fan motor at 12VDC 2Amps. Is it possible for me to buy a fan that is 12VDC with a current rating of 5.4Amps? The fan motor is powerd by a 12V 60 watt solar panel, would my problem be solved by simply getting a bigger solar panel that is rated with higher Volts or Watts?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Probably.
    I think, yes.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    If you'll notice, the answers from #12 are completely useless. He did that on purpose.
    Your questions have no meaning because we have no context. Do you *want* a larger fan? Is there a reason why it has to draw 5.4 A? What is the project? Can you post your diagram? The more you keep to yourself, the more you are wasting your time.
    ak
  4. crutschow
    Mar 14, 2008
    13,523
    3,391
    And exactly why do you think that's a problem?
  5. jermyc
    Feb 24, 2016
    8
  6. jermyc
    Feb 24, 2016
    8
    heres the diagram... i have already changed the wind turbine to 24vdc and solar panel is current at 60 watts 12vdc. Battery is 12v[​IMG]
  7. jermyc
    Feb 24, 2016
    8
    im sorry that is the wrong schematic, this is it.[​IMG]
  8. GopherT
    Nov 23, 2012
    6,339
    4,083
    What is the purpose of the fan? To spin the wind turbine? What is the capacity of the battery and what fraction of time is the fan running (again, what is the purpose of the fan?).
    If the battery has enough charge and, although it consumes more power in a second than the solar panel can produce, if it consumes fewer watts on a given day than the solar panel can produce, the. It should be fine.
    Just note, you have a "System" and your first post described a few parts. The presence of a battery and the possibility that the fan is not running 100% of the time changes everything. How about a description of the use of the system and specs of each part.
  9. jermyc
    Feb 24, 2016
    8
    yes to spin wind turbine, the battery is 12v, the fan is running 12 hours on/solar panels 12 on
  10. GopherT
    Nov 23, 2012
    6,339
    4,083
    So you want to spin the wind turbine to make energy to charge the battery?
  11. jermyc
    Feb 24, 2016
    8
    more energy storage based, but yes pretty much. I will not go into detail how it exactly works but that basically describes the process. So what do you think i should increase/change on the diagram to anwser my previous question?
  12. GopherT
    Nov 23, 2012
    6,339
    4,083
    What you need to increase? You need to increase your understanding of the laws of thermodynamics - the 8th-grade level version should be sufficient. Additionally, you might want to increase your understanding of efficient power transfer (air from a fan to a wind turbine is not a good option).
    I think you should share some detail behind this seemingly convoluted solution before we try to solve your solution. We would rather help solve your problem.
  13. jermyc
    Feb 24, 2016
    8
    I understand Thermodynamics..... I know energy cannot be created nor destroyed only moved. I have done the power Calculation and Efficiency of my system. i have calculated net power and power used.
    What i want increase, is my amps. I believe i anwsered my own question, i need to increase volts. Thanks anyway.
  14. AnalogKid
    Aug 1, 2013
    4,709
    1,301
    Good luck with that.
    ak
  15. Alec_t
    Sep 17, 2013
    5,980
    1,138
    What figure did you get for efficiency?
  16. shortbus
    Sep 30, 2009
    4,098
    1,697
    Why do you guys here always try to hold back over unity? What energy company are you working for? I saw it on the net, so I know it will work. jermyc, you might want to consider using a light bulb over your solar panel to get even more power.
    Evanguy likes this.
  17. jermyc
    Feb 24, 2016
    8
    I came on this forum for help and only got bashed, by people who dont have vision, or a sense of creativity. Anything is possible, it just goes to show you dumb fucks will not be the 1 to create something special. PEACE:rolleyes:
  18. GopherT
    Nov 23, 2012
    6,339
    4,083
    That is not even close to being true.
    The second half of your comment is what we have been trying to say all along (you forgot a comma).
    Thanks for stopping by.
    Evanguy and shortbus like this.
  19. blocco a spirale
    Jun 18, 2008
    1,463
    372
    Your ignorance is astonishing.
    Evanguy likes this.
  20. ISB123
    May 21, 2014
    1,240
    531
    If this worked you really think that people wouldn't already be using giant fans in front of turbines?
