Trying to create a blinking LED
Discussion in 'General Electronics Chat' started by sebastianpatten, Dec 21, 2010.
  1. sebastianpatten
    Nov 28, 2010
    18
    Hi there - I think I've got my head around a basic circuit, but I want to create something a bit more tricky - a single blinking LED. I would like to achieve this using NPN transistors, capacitors, 1 led and resistors.
    Has any one seen any good schematic or diagram with how the current, voltage make it work?
    I've been trying to work it out on paper to no avail.
    Thank you!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
  4. sebastianpatten
    Nov 28, 2010
    18
    I guess another follow up question would be - is it normal to try to do this in this manner - or should i be using something like a 555 chip? I've seen them mentioned a lot with regards to oscillation.
  5. tom66
    May 9, 2009
    2,613
    214
    A 555 timer is the best option for stability and accuracy, but of course requires the 555 chip itself, which isn't among the components you specified.
  6. shteii01
    Feb 19, 2010
    3,521
    515
    I would use clock chip. We did this sort of thing in second year EE course, but we used frequency generator for the clock.
    That is also the point of the multivibrator mentioned above, based on values of the components, it will act as frequency generator, the clock.
    Connect the clock and source to AND gate. Source is always On, when clock is On, the AND gate output is On and led light up. Otherwise, led does not light up.
    So all you need is clock chip, AND gate IC like 74LS08, led, resistor, voltage source.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    There are a lot of ways to do it, all of them need an oscillator of some sort.
    Flashers, Chasers, 555's Blog by member Bill Mardsen here has great information and schematics.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I like the low voltage long duration variety myself.
    This is simple.
    The 555 Projects
    CMOS 555 Long Duration Minimum Parts LED Flasher
    I figure it will last a year with two alkaline D cells. This circuit depends on the low power supply voltage, do not use more voltage or things will smoke. You can buy the CMOS 555 from Radio Shack.
    The low power supply voltage makes the chip into the LED resistor. More power supply voltage and that chips resistance goes down.
  9. marshallf3
    Jul 26, 2010
    2,358
    201
