As I indicated in my introductory message in the newb forum, I am woefully underinformed in this area, so please be patient and confine your mockery to a mild riot of abuse.
Problem: Trying to determine roughly how many kilowatts per hour are consumed by a Novatek Novair 1000 air filtration unit so that I can calculate the cost of running the machine continuously for a 24 hour period under local utility rates (here in Burbank, CA).
The specs listed on the machine itself are as follows (see pdf attached to this post for photo of specs posted on machine):
amps: 10
volts: 115
Hertz: 60
There are two settings:
Low = 600 CFM (cubic feet per minute)
High = 1000 CFM (cubic feet per minute)
I tried to figure it out myself using this online calculator: http://www.rapidtables.com/calc/electric/Amp_to_kW_Calculator.htm
But then the calculator asked for the "power factor," which I do not know.
I attempted to look that up and found this, which did not help me: http://www.allaboutcircuits.com/vol_2/chpt_11/3.html
So now I am trying to figure out the power factor so that I can calculate the kilowatts per hour.
But when I have done so, I still need to figure out how many kilowatts per hour the machine uses on the "Low" setting and on the "High" setting.
Any useful, constructive, direct answers will be greatly appreciated.
amps: 10
volts: 115
Hertz: 60
