I'm trying to make a miniaturem, battery powered fog machine, and I have no clue where to get started when it comes to the electronic part of the machine.
The machine needs to be 6 inches or less in length, 3 inches or less in width, and 2 inches or less in height.
The hopefully includes the battery, but I can get away with the battery being separate.
The budget is less than 500$. This will be in close contact to skin, so it needs to be thermally and electrically insulated.
Here are my ideas so far (kinda strays away from electronics). Please be patient with me, since I know little about electronics.
The fluid to be vaporized will flow in slowly. Glycerin-water combo. My first idea (I know it's stupid) was to have a peltier element sandwiched against a metal plate or something with a .5mm gap between them for the fluid. The peltier could be turned on and off at whim. I'm just not sure about the temperatures that the peltier can produce.
My other idea is to use a regular heating element or something instead of a peltier. I have no clue where to start when it comes to heating elements, and the circuitry needed for them.
Please be patient and help me out
