TRUTH TABLE
Discussion in 'Homework Help' started by danglin, Feb 22, 2005.
  1. danglin
    Feb 22, 2005
    Ok, need help with Truth Table, I think what I did is incorrect..not
    sure if it's the circuit diagram so I am including it. Can you redo the
    truth table so I see what you did and use as reference moving forward. I
    am pulling my hair in frustration.
    Thanks for all your help.
    see athached
  2. dragan733
    Dec 12, 2004
    152
    No, the output function is:
    Q=ABC'D'+A'BCD'+A'B'CD+AB'C'D+AB'CD'+A'BC'D=A'B'CD+ABC'D'+(A'B+AB')(C'D+CD')
  3. spveer
    Feb 27, 2005
    Hello...
    Is an answer to this question possible?
    Can anyone show me how this can be solved?
    given 2 inverters and an infinite numbers of 2-input AND and OR gates.
    Task is to get an output a', b', c', given inputs a, b, c.
    inputs------>outputs
    a------------->a’
    b------------->b’
    c------------->c’
    (using 2 inverters and an infinite numbers of 2-input AND and OR gates)
    I need the solution today pls
    Pradeep
